Ubuntu 8.04 and later provide encryption using LUKS and eCryptfs.
The question is how to configure preseed to do it automatically? There is an option in preseed to encrypt user's home, but no option for full disk encryption:
d-i user-setup/encrypt-home boolean false
Any suggestions? Thanks in advance!
htorque
  • 66,086
amin
  • 449
it seem i have to solve my problem on my own,but i put notes to guide others. the error caused on:
d-i partman-auto/method string crypto
to prevent such error first try d-i partman-auto/method string lvm and solve errors, a sample is:
d-i partman-auto/disk string /dev/sda
d-i partman-lvm/device_remove_lvm boolean true
d-i partman-lvm/device_remove_lvm_span boolean true
d-i partman-auto/purge_lvm_from_device  boolean true
d-i partman-auto-lvm/new_vg_name string system
#d-i partman-auto/init_automatically_partition \
#  select Guided - use entire disk and set up LVM
d-i partman-auto/expert_recipe string                         \
      boot-root ::                                            \
              40 300 300 ext3                                 \
                      $primary{ }                             \
                      $bootable{ }                            \
                      method{ format } format{ }              \
                      use_filesystem{ } filesystem{ ext3 }    \
                      mountpoint{ /boot }                     \
              2000 10000 1000000000 ext3                      \
                      $lvmok{ }                               \
                      mountpoint{ / }                         \
              8000 8000 200% linux-swap                       \
                      $lvmok{ }                               \
                      method{ swap } format{ }                \
d-i partman-lvm/confirm boolean true
d-i partman/confirm_write_new_label boolean true
d-i partman/choose_partition select Finish partitioning and write changes to disk
d-i partman/confirm boolean true
after you got answar of lvm method you can change method to crypto
amin
  • 449
