From what I understand, Debian testing/unstable/experimental are rolling release, right? Since Ubuntu is based on Debian, could I the Debian testing repo to my software sources and make my Ubuntu a rolling release?
Would that be possible and how would I add Debian to my sources? If it were possible, does that mean when Ubuntu 13.04 comes out, I wouldn't have to upgrade as my computer is already up to date? Unity stuff doesn't matter to me, I use Gnome Remix.
John
  • 917
What That Wouldn't Do
You can add Debian's software sources in Ubuntu the same way you add them in Debian. This will not do what you seem to be saying you want, though. You should almost certainly not do this.
This will not give you the same software that will appear in Ubuntu 13.04 in the future, because Ubuntu's packages are specially built for Ubuntu, incorporate some changes compared to the Debian versions, and because your package versions would almost always be ahead of the ones in Ubuntu (especially on Ubuntu 13.04's release date, which would take place well after a freeze on the introduction of new features).
Ubuntu's packages are not identical to the packages in Debian, and you cannot get the same exact packages through an official Debian software source that you get through an official Ubuntu software source.
What That Might Do
If you added Debian's experimental software sources to your Ubuntu system, they would almost always have higher-versioned packages than provided by the Ubuntu software sources (since most Ubuntu packages come from Debian). Consequently all the software in your system would be upgraded to the Debian experimental versions. This upgrade process would very likely fail, leaving your system or the package manager in a non-functional state.
However, if it succeeded, the result would be a Debian experimental system that happens to have some Ubuntu repositories enabled (but providing almost no software).
You mentioned that you don't need "Unity and stuff." By "and stuff" I presume you mean other packages present in Ubuntu but not Debian. Since you don't need any Ubuntu packages and you're interested in using a system where all the packages are provided by Debian's official software sources, it sounds like what you really want to do is use Debian.
Debian, like Ubuntu, is an excellent operating system. Go for it!
But please don't try to "upgrade" an Ubuntu system to Debian; you should install Debian in an officially supported way. If you want to use experimental packages, you can get plenty of excitement that way, and find and report bugs while you're at it. In contrast, there's not much value to making a broken Debian system out of an Ubuntu system.
To Stay on the Bleeding Edge of Ubuntu
If you want to use the latest development packages for Ubuntu 13.04 before it comes out, then instead of using Debian's experimental software sources, you should test 13.04.
New, experimental installation ISO's for Ubuntu come out every day and can be downloaded here. Once installed your alpha Raring Ringtail system will get lots of updates and plenty of stuff won't work right. It might even not work at all, or stop working at some point. (That's what it's like to use the most experimental software available.)
It's fun, though I don't recommend this for a system you rely on, even casually.
If you want you can upgrade an Ubuntu 12.10 Quantal Quetzal system to alpha Raring:
sudo apt-get update
sudo do-release-upgrade -d
If alpha testing interests you, check out these resources:
Eliah Kagan
  • 119,640
The simple answer is no.
Regular Ubuntu releases are based on Debian Unstable, and some vanilla Debian packages are incompatible with Ubuntu (and vise-versa). Expect problems after adding Debian testing to Raring.
To summarize, either use Debian Testing, Debian Unstable, or Ubutnu Development branches. Either of them is, in a way, a rolling release, and if you use 13.04, and keep installing updates, it should bring you up to the release version. Better still, use any of the rolling release distros out there.
mikewhatever
  • 33,013
