I installed Windows 8 and after that I installed Ubuntu. This are my partition now:
  • 70Gb --> Windows 8
  • 50Gb --> Ubuntu 12.10
  • 100Mb --> UEFI
  • 300Mb --> Recovery
I installed the GRUB on /dev/sda. Then, after GRUB not showing up and booting directly into Windows 8, I turned the laptop off and booted again into Ubuntu LiveCD and ran the Boot-repair utility, it give me this information but it didn't solved the problem.
My Laptop still boots directly into Windows 8, without GRUB or Ubuntu even showing up.
Lucio
  • 19,191
  • 32
  • 112
  • 191
Philipp
  • 61
5 Answers5
Install Boot-Repair on ubuntu by following steps
Open the terminal and run the following commands
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install boot-repair
After completing the installation you can launch it from System->Administration->Boot-Repair menu if you use Gnome, or search "boot-repair" in the dash if you use Unity. Then follow the following screenshots:
Method 1
  • Click on the advanced options
Initial screen
  • Tick the options shown below
advanced option
  • Change the tab to Grub Location Tab and Tick The options Shown in the figure
Press Apply and Reboot the system
Method 2
  • Select the recommended Boot repair options as shown in the first screenshot
Stormvirux
  • 4,536
Chances are that one of two things is happening:
  • Ubuntu didn't completely install its boot loader, in which case you need to use the efibootmgr program from a Linux emergency disc to finish the job. Overall, this seems a bit unlikely, but it's the possibility that I hope is correct.
  • Your firmware is one of the many broken designs that violates the EFI spec and boots Windows despite the fact that another boot loader is correctly configured as the default.
There are several possible solutions, depending on which of these things is happening and your personal preferences for how to proceed. These include:
  • Boot a Linux emergency disc in EFI mode and type sudo efibootmgr -c -p 2 -d /dev/sda -l "\EFI\ubuntu\grubx64.efi" -L "Ubuntu" to re-register Ubuntu's boot loader with the ESP. You may need to change /dev/sda if your method of booting changes what is currently /dev/sda to something else. Depending on the disc you use, you may also need to install efibootmgr and perhaps do an insmod efivars before using efibootmgr. This method will work only if my first hypothesis about what is wrong is correct.
  • Run the Boot Repair tool and tell it to fix things. This has a high probability of working and is easy to do, but it will likely do so in a way that could create further problems down the road. If it doesn't work, it will become harder to disentangle everything.
  • Mount the EFI System Partition (ESP; your /dev/sda2), move the EFI/Microsoft/Boot/bootmgfw.efi file down one level (so that it's EFI/Microsoft/bootmgfw.efi), and then copy EFI/ubuntu/grubx64.efi to EFI/Microsofot/Boot/bootmgfw.efi. This is the key thing that Boot Repair would do, but done in a slightly different way. You'll then need to modify your /boot/grub/grub.cfg file before you'll be able to boot Windows. I'm not sure if the update-grub script will pick up the change automatically. It might, but if not, you'll need to create a new Windows entry in /etc/grub.d/40_custom for the new location of bootmgfw.efi.
  • Download and install my rEFInd program. There are several ways to do this, each with its own quirks and caveats. If you can get your non-booting installation to boot, say by using Super GRUB 2 Disk, installing the Debian package is likely (but not certain) to succeed. Depending on how it's installed, rEFInd may be able to boot Linux directly, without the use of GRUB.
Rod Smith
  • 45,120
  • 66
  • 108
It is likely to be a firmware that violates the UEFI specs.
To workaround this, run Boot-Repair --> Advanced options --> tick Backup and rename EFI files --> Apply. Indicate the new URL that will appear if any doubt.
LovinBuntu
  • 3,785
Thanks for the help. This has helped me a lot to find my own way. My boot-repair looked different though. Total sum of what I did to get GRUB for both windows 8 and Ubuntu.
  • In Bios. Make boot menu look for regular HDD first before going to Windows Boot.
  • Load into Ubuntu.
  • Follow the post to install and use boot-repair
Only for me it didn't show the options shown. On GRUB location I had minimal options.
OS to load to : Here I chose : Windows (Via sd5 window) <--sda5 is partition of my Ubuntu
Sperate/bot/efi partition : : sda2 <-- sda2 is partition of my Windows.
Pop up window followed asking me to fix Windows boot ->> I clicked yes.
Now on startup it will load Ubuntu GRUB and go automatically to windows after 10 seconds unless I choose Ubuntu. I hope that I have made it clear, and hope I can help at least one person.
Simon
  • 4,843
  1. F12 while ubuntu is loading
  2. Repair mode
  3. Grub
  4. wait
  5. reboot
Oduvan
  • 111
