Due to a bad update to 11.04 i had to completely reinstall Ubuntu, now i got everything pretty much the way it was before, except for plymouth.I've tried every script i found, every turorial i've found,
i've installed Plymouth Manager, i've installed a plymouth theme that worked before...and still, just plain white text, if it feels like showing me something, 'cause at times i don't even get to see the text mode, so, is there anything i can do witthout removing the ATI driver?, can i get rid of plymouth if it's not going to properly work?, are there an alternatives to plymouth?
Uri Herrera
  • 15,318
Just in case you didn't find this tutorial, it worked for me:
http://kyleabaker.com/2010/07/11/how-to-fix-your-ubuntu-boot-screen/
Rather than fixing Plymouth, I believe this just uses framebuffer during boot with a user-chosen resolution. It will give you more than text during boot, at least.
JPL
  • 116
-1
Uri,
Check out the link below it helped me when I was creating my own Ubuntu distro.
http://www.n00bsonubuntu.net/content/install-ubuntu-10-10-plymouth-theme-on-ubuntu-10-10-maverick-meerkat/
