Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
mplayer : Depends: libavcodec52 (>= 4:0.5.1-1) but it is not installable or
libavcodec-extra-52 (>= 4:0.5.1-1) but it is not installable
Depends: libavformat52 (>= 4:0.5.1-1) but it is not installable or
libavformat-extra-52 (>= 4:0.5.1-1) but it is not installable
Depends: libjack0 (>= 0.118+svn3796) but it is not installed
Depends: libjpeg62 but it is not installed
Depends: liblzo2-2 but it is not installed
Depends: libmpcdec3 but it is not installable
Depends: libx264-85 but it is not installable
Recommends: apport-hooks-medibuntu but it is not installable
E: Unmet dependencies. Try using -f.
Asked
Active
Viewed 362 times
-1
Open a terminal, and run:
sudo apt-get -f install
Please be careful about what packages it removes, updates and installs. If you are sure about it, answer yes and let it do its job. If you are unsure, post the full output here and I'll try to give you some advice.
It seems that you've added a 3rd party repository that is not getting very well with your Ubuntu version.
When adding 3rd party repositories, please ensure it is for the exactly same Ubuntu version that you are running now. Also, don't trust any 3rd party repository, since they can break your system.
Jorge Suárez de Lis
- 2,966
