So far I have been unable to keep an FTP user jailed to their website directory. Is there a solution that both fixes this bug and keeps the user jailed to their directory?
My vsFTPd settings that I changed:
listen_port=9000
Set: anonymous_enable=NO
Uncomment: local_enable=YES
Uncomment: write_enable=YES
Uncomment: local_umask=022
Set: connect_from_port_20=NO
Uncomment: idle_session_timeout=600
Uncomment: data_connection_timeout=120
Comment out: #ftpd_banner=Welcome to blah FTP service. [should be on line 104]
Added: banner_file=/etc/issue.net
Uncomment: chroot_local_user=YES
Uncomment: chroot_list_enable=YES
Uncomment : chroot_list_file=/etc/vsftpd.chroot_list
At the end of the file I added:
# Show hidden files and the "." and ".." folders.
# Useful to not write over hidden files:
force_dot_files=YES
# Hide the info about the owner (user and group) of the files.
hide_ids=YES
# Connection limit for each IP address:
max_per_ip=10
# Maximum number of clients:
max_clients=5
# FTP Passive Settings
pasv_enable=YES
#If your listen_port is 9000 set this range to 7500 and 8500
pasv_min_port=[port range min]
pasv_max_port=[port range max]
The user in question, mybloguser, is jailed to her/his website directory under /srv/www/myblog and this user is not part of the nano /etc/vsftpd.chroot_list file. The user’s home directory is also /srv/www/myblog which used to work in the past.
I tried the allow_writeable_chroot=YES solution which did not work, and actually broke vsFTPd completely.
I have tried:
Fixing 500 OOPS: vsftpd: refusing to run with writable root inside chroot ()
Fixing 500 OOPS: vsftpd: refusing to run with writable root inside chroot() on vsftpd
How can we both fix this error and keep the user jailed to their home directory?
