I've installed Oracle Java 7 according to this guide. When I run sudo update-java-alternatives -s java-7-oracle, it gives me :
update-alternatives: error: no alternatives for xulrunner-1.9-javaplugin.so.
update-alternatives: error: alternative /usr/lib/jvm/java-7-oracle/jre/bin/jexec for jexec not registered, not setting.
update-alternatives: error: alternative /usr/lib/jvm/java-7-oracle/jre/lib/amd64/libnpjp2.so for mozilla-javaplugin.so not registered, not setting.
What is the matter? I use ubuntu12.04 amd64.
bender
  • 1,854
waterloo2005
  • 2,057
Properly installing Oracle java 7 JDK and JRE on Ubuntu 64Bits and beased distributions.
OPTION 1: Step by Step
OPEN A TERMINAL WINDOW (uxterm or any other terminal emulator)
Run as root
sudo -i
cd /
Guarantee that command "apt-add-repository" is working (a know bug in some Ubuntu 64bits, and based distributions)
aptitude update
aptitude install python-software-properties
Install Oracle java PPA
apt-add-repository ppa:webupd8team/java
Install Oracle java
aptitude update
aptitude install oracle-java7-jdk oracle-java7-set-default oracle-java7-installer oracle-java7-plugin
Fix know Oracle java issues: part 1. Make the dir "/usr/lib/xulrunner-addons/plugins/"
mkdir -p /usr/lib/xulrunner-addons/plugins
Fix know Oracle java issues: part 2. Register missing alternatives
update-alternatives --install /usr/lib/mozilla/plugins/libjavaplugin.so mozilla-javaplugin.so /usr/lib/jvm/java-7-oracle/jre/lib/amd64/libnpjp2.so 1
update-alternatives --set mozilla-javaplugin.so /usr/lib/jvm/java-7-oracle/jre/lib/amd64/libnpjp2.so
update-alternatives --install /usr/lib/xulrunner-addons/plugins/libjavaplugin.so xulrunner-1.9-javaplugin.so /usr/lib/jvm/java-7-oracle/jre/lib/amd64/libnpjp2.so 1
update-alternatives --set xulrunner-1.9-javaplugin.so /usr/lib/jvm/java-7-oracle/jre/lib/amd64/libnpjp2.so
Fix know Oracle java issues: part 3. Correct the location of the "jexec" file in "/usr/lib/jvm/.java-7-oracle.jinfo"
sed -i 's@jre jexec /usr/lib/jvm/java-7-oracle/jre/bin/jexec@jre jexec /usr/lib/jvm/java-7-oracle/jre/lib/jexec@g' /usr/lib/jvm/.java-7-oracle.jinfo
Update java alternatives to make Oracle java to be the default java on system
Uninstall OpenJDK java files
aptitude purge openjdk-7-jre openjdk-7-jre-headless openjdk-7-jre-lib default-jre default-jre-headless icedtea-7-jre-jamvm
Logout from "root" user
exit
Close terminal window
exit
OPTION 2: ONE TIME SCRIPT
sudo -i
cd /
aptitude update
aptitude update
exit
exit
elmicha
  • 9,960
