I'm trying to set up a TFTP server using xinetd but I haven't had any luck so far. I have installed the following packages: xinetd, tftpd, tftp.
After that I changed the /etc/xinetd.d/tftp so that it would start the tftp automaticaly and even restarted the machine to see if it would work (yes, I'm that desperate...). It doesn't seem to get it working.
Then I tryed using the tftp command to get a file from another pc. Here is the thing, I can get something from another tftp server, but not from my localhost. The other machine can't fetch anything from mine either.
Oh, and I did a chmod 777 to both /tftpboot and the foo file I'm using in this test.
Anyone knows why am I the only being that can't use the tftp as it should? Just a last minute update, when I type "status" inside the tftp command I get this:
tftp> status
Not connected.
Mode: netascii Verbose: off Tracing: off
Rexmt-interval: 5 seconds, Max-timeout: 25 seconds
Thanks for the help!
