Since I run XBMC as a program, and not standalone, I would just like it to exit when I click the power button. The default behavior is to show the shutdown menu, and I don't want to accidently shut down my computer.
Remap the Power button on the home screen to quit xbmc instead of showing the shutdown menu:
You should modify the Home.xml file in your skin folder in /usr/share/xbmc. For me (Frodo RC3 with the Confluence skin) this is /usr/share/xbmc/addons/skin.confluence/720p/Home.xml.
In this file you need to replace the line (in my case line 1067, see bottom of the post on how to quickly open the file at that position)
<onclick>ActivateWindow(ShutdownMenu)</onclick>
by
<onclick>XBMC.Quit()</onclick>
Now if you click the power button in XBMC it should just exit, without showing a menu.
You need to do this again after XBMC updates since it overwrites the files in /usr/share/xbmc.
Alternatives / Notes
With the above solution you can still shutdown XBMC using a remote, or the web interface.
Instead of doing the above (simply quiting, not showing the shutdown menu) you can also edit the shutdown menu instead. The menu itself is in /usr/share/xbmc/addons/skin.confluence/720p/DialogButtonMenu.xml. The interesting menu buttons are defined from line 73 and down. The shutdown button (id=3) has the property
<visible>System.CanPowerDown</visible>
changing this to
<visible>no</visible>
should hide it from the menu. You can do the same trick for suspend, reboot, etc.
This still doesn't prevent shutting down from the webinterface I think, If only I knew how to set System.CanPowerDown=false...
If you know it please add it in the comments.
Extra: Commands to quickly open the file at the right position (1067,33)
  • Vim (If you don't know it, try to learn it, it is very nice!)
    sudo vim /usr/share/xbmc/addons/skin.confluence/720p/Home.xml +1067
    or even better (independent of actual line number)
    sudo vim /usr/share/xbmc/addons/skin.confluence/720p/Home.xml +/ShutdownMenu
  • Nano (terminal editor that is easy to use for beginners)
    sudo nano +1067,33 /usr/share/xbmc/addons/skin.confluence/720p/Home.xml
  • Gedit (Simple GUI editor)
    gksudo gedit /usr/share/xbmc/addons/skin.confluence/720p/Home.xml +1067
