Summary:
  • Folder A has only many Excelent files
  • Folder B has many folders of mixed Excelent/Good/Bad files
How can I delete files in Folder B folders only in case they will be in Folder A.
In other words, how to check if Folder A files exist in Folder B folders then delete from Folder B folders?
Idea of solution Maybe a command which:
  1. Checks part of alphabet like all starting with A
  2. Executing deletion on files found in Folder B subfolders
  3. Repeat 1. + one alphabet up.
Reasons why other duplication programs were bad:
  1. Long time until 1st deletion - it's only when finished scanning
  2. And no possibility to choose deleting in Folder B. It's possible only to keep latest and something else also, but not by choosing in which folder to keep.
Useless history: Files were copied from Recuva in Folder B and partly arranged, but a lot of them are bad. So first, I'm thinking Folder B comparing if exist to those which recovered again, but now just Excelent recovered in Folder A by Recuva so most of Excelent will be just in Folder A.
Example file tree:
├── A
│   └── Excellent
└── B
    ├── Bad
    └── Excellent
mickmackusa
  • 852
  • 20
Kangarooo
  • 5,223
Below are two solutions, depending on how we define "duplicate":
  • Files with the same relative path, or
  • Files with the same content but not necessarily the same name
If by "duplicate" we mean two files which share the same relative path, then you could use find and xargs to remove the duplicates. For example, suppose you have
~/tmp% tree A
A
└── Excellent
    ├── bar
    ├── baz
    └── foo
~/tmp% tree B
B
├── Bad
│   └── quux
├── Excellent
│   ├── bar
│   ├── baz
│   └── foo
└── Good
Then
find /home/unutbu/tmp/A  -depth -type f -print0 | xargs -0 -I{} bash -c 'rm "/home/unutbu/tmp/B${1#*A}"' - {}
results in
~/tmp% tree B
B
├── Bad
│   └── quux
├── Excellent
└── Good
Or, if by "duplicate" we mean two files share the same content, though perhaps not the same filename, then you could use rdfind:
sudo apt-get install rdfind
If we have this directory structure:
~/tmp% tree A
A
└── Excellent
    ├── bar
    ├── baz
    └── foo
1 directory, 3 files
~/tmp% tree B
B
├── Bad
│   └── quux
├── Excellent
│   ├── barbar
│   ├── bazbaz
│   └── foofoo
└── Good
where barbar has the same content as bar, and similarly for bazbaz and foofoo, then
rdfind -deleteduplicates true A B
results in
~/tmp% tree B
B
├── Bad
│   └── quux
├── Excellent
└── Good
Alternate solution in case your version of Ubuntu does not include rdfind:
You could instead use fdupes:
sudo apt-get install fdupes
fdupes --recurse --delete --noprompt A B
unutbu
  • 1,082
