20
I have a newly bought Amazon Paperwhite, but when I connect it to my PC, Ubuntu does not recognize it.
What can I do?
Braiam
  • 69,112
Englender
  • 201
I suggest trying different cables, it finally solved my problem in the end after having lost some time (Paperwhite connecting to Ubuntu Xenial).
Store-bought cables laying around appeared to only be capable of charging the device. A Huawei P9 lite original cable was the one that finally made the connection.
ggfial
  • 161
I've stumbled upon the same problem. After installing mtpfs all worked fine.
sudo apt-get install mtpfs
Don't forget to remove and insert the usb cable again.
FYI: Mine is a Kindle Touch.
Make sure to turn off the Airplane Mode on your kindle. For me, this solved it, but it took me a while to realize that it was on.
There can many reasons why one could have a problem with the USB connection, and this is one of them. Apparently, the airplane mode also disables USB, and not only network connection.
You should just be able to install calibre sudo apt-get install calibre, and manage your Kindle Paperwhite. I don't have a new-ish kindle to test with, but that method has worked with the older kindles, and I don't think they changed it much.
