-1
I installed x11rdp using the tip here How to install and configure X11RDP?, its a script that download, build, install and configure x11rdp, I ran once the sudo bash setup.sh, it didn't work because I didn't have the command make so I installed it, the make command ran without trouble except by the package libxcb1-dev, who seems broken, I tried ran apt-get -f install, it didn't work again, I tried update by the update manager, same problem again, I tried use synaptic and didn't work again, any idea to solve that problem or any idea if is something that I have done wrong or that script has done wrong or if its a problem in the package?? by the way, even with the broken package I could install x11rdp with the script and I am using without trouble.
here the LOG:
 libxcb1-dev: Depends: libxcb1 (= 1.8.1-1) but 1.8.1-1ubuntu0.1 is installed
Depends: libxau-dev (>= 1:1.0.0-1) but 1:1.0.6-4 is installed
Depends: libxdmcp-dev (>= 1:1.0.0-1) but 1:1.1.0-4 is installed
 ldconfig deferred processing now taking place
and log into the `apt-get -f install`
  libxcb1-dev
  libx11-dev
  libxfixes-dev
 A package failed to install.  Trying to recover:
 dpkg: dependency problems prevent configuration of libxcb1-dev:
  libxcb1-dev depends on libxcb1 (= 1.8.1-1); however:
   Version of libxcb1 on system is 1.8.1-1ubuntu0.1.
 dpkg: error processing libxcb1-dev (--configure):
  dependency problems - leaving unconfigured
 dpkg: dependency problems prevent configuration of libx11-dev:
  libx11-dev depends on libxcb1-dev; however:
   Package libxcb1-dev is not configured yet.
 dpkg: error processing libx11-dev (--configure):
 dpkg: dependency problems prevent configuration of libxfixes-dev:
  libxfixes-dev depends on libx11-dev; however:
   Package libx11-dev is not configured yet.
 dpkg: error processing libxfixes-dev (--configure):
  libxcb1-dev
  libx11-dev
  libxfixes-dev
Install build-essential Install build-essential if you have not done so already. This provides various packages useful for building software in Ubuntu. It can be installed in the Software Center or by running:
sudo apt-get update && sudo apt-get install build-essential
