I recently installed Sun's Java because of performance issues running Minecraft.
When I try to remove the OpenJDK packages by
sudo apt-get purge openjdk*
however, the JDownloader package is being removed as well. If I try to remove all OpenJDK-7 packages one by one, OpenJDK-6 is being installed instead.
IMHO there should be a way to satisfy JDownloader's dependencies for a Java runtime environment with Sun's version.
Is there any way to keep JDownloader while completely removing the opensource Java versions?
EDIT: As explained by user tumbleweed, this issue was caused by a temporary bug which soon afterwards has been resolved.
FuzzyQ
  • 2,398
You could let the system remove it and then install it again with the option --no-install-recommends.
That will ignore the necessary dependencies listed on the package and install only the package it self.
More information on that subject here:
Bruno Pereira
  • 74,715
The real answer here is that that package was buggy, it depended on specific JDKs rather than the generic javaX-runtime virtual packages.
I pointed this out to the maintainer of the PPA, and he's uploaded a new version that depends on default-jre | java6-runtime | java7-runtime. This should be satisfied by the Sun JDK.
tumbleweed
  • 8,106
