I am new to linux and was wondering why launching applications is so slow. I've tried both Ubuntu 12.10 64 bit and Ubuntu 12.04 LTS 64 bit
Computer Specs: Toshiba Satellite p755 CPU: Intel core i7-2670QM @2.20GHz Ram: 8 GB Using integrated intel hd 3000 graphics
When I install the first thing I do is update, which takes about an hour or so. I would assume I'd be good after that, but when launching things like the firefox, system settings, thunderbird it takes a much much longer time than on Windows 7. Please help me.
Braiam
  • 69,112
End of life for Ubuntu 12.10 is May 16, 2014. Ubuntu 12.04 is April 2017.
However Ubuntu 14.04 is already out and is most updates one. Hence, please use that to be at the better side.
Now, for the performance issue; go to Software Center and type "LXDE" and install the first option. You may use this command in terminal as well: sudo apt-get install lxde
LXDE is Lubuntu!! Consider it another name for the same thing. This will make you able to choose between "Unity" (which is the default desktop you know about) and LXDE which is awesome and lightweight.
You can also use "XFCE" as same way as "LXDE" from software center or type in the following command in terminal: sudo apt-get install xfce4
XFCE is Xubuntu. It is lighter than regular Ubuntu but heavier than LXDE. And yes, in both cases, you have to restart your computer.
Hope that helps !!
Try Ubuntu 12.04/13.10 32 bit
At first this may seem weird, but the truth is that 32 bit OS works very well on 64 bit systems.You can download 32 bit OS from here.
Try Lubuntu/Xubuntu
If the first option does not work, You can use Xubuntu or Lubuntu(again I suggest you to use 32 bit OS)
Get Xubuntu from here.
Get Lubuntu from here.
For more info read can-a-32-bit-os-run-in-a-64-bit-processor?
