I am trying to compile the OpenCV library on a shared drive on my system. I was able to configure and generate makefiles successfully by using these settings, but when I try to compile I get the following error:
Linking CXX shared library ../../lib/libopencv_core.so
CMake Error: cmake_symlink_library: System Error: Operation not permitted
make[2]: *** [lib/libopencv_core.so.2.4.3] Error 1
make[1]: *** [modules/core/CMakeFiles/opencv_core.dir/all] Error 2
make: *** [all] Error 2
How do I resolve this issue?
I think it may be an issue with the mount flags.
Alexis Wilke
  • 2,787
bubble
  • 399
This happens, because vfat type filesystems don't support symlinks. Mount flags won't change this situation.
I'm not familiar with CMake, but I suppose you are using some kind of rule in your makefile that is telling CMake to make a symbolic link to lib/libopencv_core.so.2.4.3, which fails.
bender
  • 1,854
I ran into the same problem, because I was running on a virtual box instantiation of ubuntu (guest), but running in a shared folder to my mac (host).
Because symlinks are different on the mac, cmake failed. Moving the build directory to a ubuntu only folder (not shared with the mac) solved the problem.
Moral of the story- don't build in shared folders that cross platforms.
arinmorf
  • 141
