I installed the latest version of x64 lubuntu and I want to install a scheme interpreter. Strangely, in Synaptic, only the debugger and documentation is available to install.
I would rather not compile my own version because this would be hard to maintain in the future.
How do I resolve this problem?
mike@ubuntu:~/Desktop/aplan$ sudo apt-get install mit-scheme
Reading package lists... Done
Building dependency tree
mit-scheme:i386 : Depends: libmhash2:i386 but it is not going to be installed
Recommends: mime-support:i386 but it is not installable
