232
I'm trying to add new module to nginx with naxsi, but I should reinstall nginx. What is the better way of removing nginx?
Shuo
  • 2,433
  • 15
Removes all but config files.
sudo apt-get remove nginx nginx-common
Removes everything.
sudo apt-get purge nginx nginx-common
After using any of the above commands, use this in order to remove dependencies used by nginx which are no longer required.
sudo apt-get autoremove
squareborg
  • 10,737
15
Uninstall everything and install once again
sudo apt remove --purge nginx*
sudo apt autoremove
sudo apt update
sudo apt install nginx
Enjoy
MD SHAYON
  • 415
