I have configured hostapd as an access point following several how-tos using ubuntu 12.04. Everything works well for up to several hours and then at some point hostapd no longer accepts new connections.
hostapd config is as follows:
ssid=PNN
wpa_passphrase=somePassphrase
interface=wlan2
bridge=br0
auth_algs=3
channel=7
driver=nl80211
hw_mode=g
logger_stdout=-1
logger_stdout_level=2
max_num_sta=255
rsn_pairwise=CCMP
wpa=2
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP CCMP
Using the output of
hostapd -dd /etc/hostapd/hostapd.conf
Under normal circumstances new connections are picked up as follows:
mgmt::proberesp cb
unknown vendor specific information element ignored (vendor OUI 00:10:18 len=9)
STA 40:a6:d9:a5:63:dd sent probe request for broadcast SSID
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
STA 40:a6:d9:a5:63:dd sent probe request for our SSID
mgmt::proberesp cb
Unknown Microsoft information element ignored (type=8 len=7)
STA 3c:d0:f8:10:0f:f0 sent probe request for broadcast SSID
mgmt::auth
authentication: STA=40:a6:d9:a5:63:dd auth_alg=0 auth_transaction=1 status_code=0 wep=0
New STA
wlan2: STA 40:a6:d9:a5:63:dd IEEE 802.11: authentication OK (open system)
wlan2: STA 40:a6:d9:a5:63:dd MLME: MLME-AUTHENTICATE.indication(40:a6:d9:a5:63:dd, OPEN_SYSTEM)
wlan2: STA 40:a6:d9:a5:63:dd MLME: MLME-DELETEKEYS.request(40:a6:d9:a5:63:dd)
authentication reply: STA=40:a6:d9:a5:63:dd auth_alg=0 auth_transaction=2 resp=0 (IE len=0)
mgmt::proberesp cb
mgmt::auth cb
wlan2: STA 40:a6:d9:a5:63:dd IEEE 802.11: authenticated
mgmt::assoc_req
association request: STA=40:a6:d9:a5:63:dd capab_info=0x431 listen_interval=10
new AID 1
wlan2: STA 40:a6:d9:a5:63:dd IEEE 802.11: association OK (aid 1)
mgmt::assoc_resp cb
wlan2: STA 40:a6:d9:a5:63:dd IEEE 802.11: associated (aid 1)
wlan2: STA 40:a6:d9:a5:63:dd MLME: MLME-ASSOCIATE.indication(40:a6:d9:a5:63:dd)
wpa_driver_nl80211_set_key: ifindex=6 alg=0 addr=0x216f2b0 key_idx=0 set_tx=1 seq_len=0 key_len=0
addr=40:a6:d9:a5:63:dd
wlan2: STA 40:a6:d9:a5:63:dd WPA: event 1 notification
wlan2: STA 40:a6:d9:a5:63:dd WPA: start authentication
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state INITIALIZE
wlan2: STA 40:a6:d9:a5:63:dd IEEE 802.1X: unauthorizing port
WPA: 40:a6:d9:a5:63:dd WPA_PTK_GROUP entering state IDLE
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state AUTHENTICATION
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state AUTHENTICATION2
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state INITPSK
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state PTKSTART
wlan2: STA 40:a6:d9:a5:63:dd WPA: sending 1/4 msg of 4-Way Handshake
WPA: Send EAPOL(version=2 secure=0 mic=0 ack=1 install=0 pairwise=8 kde_len=0 keyidx=0 encr=0)
nl80211: Event message available
nl80211: Ignored unknown event (cmd=19)
IEEE 802.1X: 40:a6:d9:a5:63:dd TX status - version=2 type=3 length=95 - ack=1
IEEE 802.1X: 121 bytes from 40:a6:d9:a5:63:dd
IEEE 802.1X: version=2 type=3 length=117
wlan2: STA 40:a6:d9:a5:63:dd WPA: received EAPOL-Key frame (2/4 Pairwise)
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state PTKCALCNEGOTIATING
WPA: PTK derivation - A1=00:0e:8e:3f:f9:71 A2=40:a6:d9:a5:63:dd
WPA: PMK - hexdump(len=32): [REMOVED]
WPA: PTK - hexdump(len=48): [REMOVED]
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state PTKCALCNEGOTIATING2
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state PTKINITNEGOTIATING
wlan2: STA 40:a6:d9:a5:63:dd WPA: sending 3/4 msg of 4-Way Handshake
WPA: Send EAPOL(version=2 secure=1 mic=1 ack=1 install=1 pairwise=8 kde_len=46 keyidx=1 encr=1)
Plaintext EAPOL-Key Key Data - hexdump(len=56): [REMOVED]
IEEE 802.1X: 40:a6:d9:a5:63:dd TX status - version=2 type=3 length=151 - ack=1
IEEE 802.1X: 99 bytes from 40:a6:d9:a5:63:dd
IEEE 802.1X: version=2 type=3 length=95
wlan2: STA 40:a6:d9:a5:63:dd WPA: received EAPOL-Key frame (4/4 Pairwise)
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state PTKINITDONE
wpa_driver_nl80211_set_key: ifindex=6 alg=3 addr=0x216f2b0 key_idx=0 set_tx=1 seq_len=0 key_len=16
AP-STA-CONNECTED 40:a6:d9:a5:63:dd
wlan2: STA 40:a6:d9:a5:63:dd IEEE 802.1X: authorizing port
wlan2: STA 40:a6:d9:a5:63:dd RADIUS: starting accounting session 50E3DF21-00000000
wlan2: STA 40:a6:d9:a5:63:dd WPA: pairwise key handshake completed (RSN)
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
STA 5c:95:ae:d8:b7:ec sent probe request for broadcast SSID
mgmt::proberesp cb
Once hostapd no longer accepts new connections the output is as follows:
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::auth
New STA
mgmt::auth cb
mgmt::assoc_req
new AID 1
mgmt::assoc_resp cb
wpa_driver_nl80211_set_key: ifindex=6 alg=0 addr=0x263c270 key_idx=0 set_tx=1 seq_len=0 key_len=0
wlan2: STA 40:a6:d9:a5:63:dd WPA: EAPOL-Key timeout
STA 00:15:6d:60:da:3b sent probe request for broadcast SSID
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state DISCONNECT
hostapd_wpa_auth_disconnect: WPA authenticator requests disconnect: STA 40:a6:d9:a5:63:dd reason 2
WPA: 40:a6:d9:a5:63:dd WPA_PTK entering state DISCONNECTED
wlan2: STA 40:a6:d9:a5:63:dd IEEE 802.11: deauthenticated due to local deauth request
nl80211: Ignored unknown event (cmd=20)
mgmt::proberesp cb
mgmt::proberesp cb
mgmt::proberesp cb
STA 40:a6:d9:b0:cd:fd sent probe request for broadcast SSID
mgmt::proberesp cb
Running the following fixes the problem for another couple of hours.
sudo service hostapd restart
I've done as much reading as possible and have tried reducing the txpower of wlan2 from 16dbm to 10dbm as suggested for stability problems but the problem remains.
If anyone could assist it would be greatly appreciated.
