37
I have a new android phone that has a number of apps for communicating though an ssh connection. I would like to know if I can use ssh commands if I can simulate key pressed, specifically the media keys (play pause volume). I would prefer not to install additional software.
Note: I know there are apps that do this out of the box, this is simply for a better understanding.
The answer is xdotool, and it might already be installed on your Ubuntu system. It can simulate keypresses. See also [1].
Some commands:
  • play/pause
    xdotool key XF86AudioPlay
  • previous/next
    xdotool key XF86AudioPrev
    xdotool key XF86AudioNext
  • volume down/up
    xdotool key XF86AudioLowerVolume
    xdotool key XF86AudioRaiseVolume
  • mute
    xdotool key XF86AudioMute
For more XF86 commands see [2].
Instead of doing the volume step by step you can also set it using alsamixer or pulseaudio (recommended). Assuming you use device 0 (you can check this with alsamixer or pacmd list-sinks) you can set the volume to for instance 80% with
  • alsamixer (-c 0 specifies the sound device id)
    amixer -c 0 sset Master,0 80%
  • pulseaudio (the 0 in front of the 80% is the sound device id)
    pactl set-sink-volume 0 80%
For more information about these commands see their manpages.
EDIT: If you're trying to do the xdotool commands over ssh and get the following error message
Error: Can't open display: (null)
Segmentation fault
you need to set the DISPLAY variable:
export DISPLAY=':0.0'
After that it should work without problems
[1] http://www.semicomplete.com/projects/xdotool/xdotool.xhtml
[2] http://wiki.linuxquestions.org/wiki/XF86_keyboard_symbols
