I would like to set up a scheduled task via anacron but I would like to do so in user mode. How can I achieve this?
- 21,763
You can set up a separate anacron instance to run in user mode:
Create a
.anacronfolder in your home directory and in it two subfolders,etcandspool:mkdir -p ~/.anacron/{etc,spool}Create a new file
~/.anacron/etc/anacrontabwith contents similar to the following:# /etc/anacrontab: configuration file for anacron # See anacron(8) and anacrontab(5) for details. SHELL=/bin/bash PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin # period delay job-identifier command 1 10 testjob test.shAdd the following line to your crontab using
crontab -e:@hourly /usr/sbin/anacron -s -t $HOME/.anacron/etc/anacrontab -S $HOME/.anacron/spool
- 40,956
- 21,763
The anacrontab shown above has a problem: anacron looks for executables only in the directories specified in PATH. So it will not find test.sh.
A better solution is to use the command run-parts:
SHELL=/bin/sh
1 10 dailyjob run-parts ${HOME}/.anacron/daily/
This requires that we create the directory daily:
mkdir -p ~/.anacron/{etc,spool,daily}
run-parts will not execute scripts with '.' in the name, such as "test.sh", so rename the script to, for example, "my-test".
There is yet another wrinkle: If the computer does not run 24/7, then one does not have control over at what time the daily script is run. I have a web scraping script that I want to be run at about 11 am, or later during the day. I fix this problem by scheduling the web scraping job in the "at" facility (sudo apt install at).
So I have a script daily/crawl which looks as follows:
#!/bin/bash
preferred_time="11:15"
scheduled_time="${preferred_time}"
preferred_time_as_number="${preferred_time/:/}"
current_time_as_number=$(date +%H%M)
if [ "${current_time_as_number}" -ge "${preferred_time_as_number}" ]; then
scheduled_time="NOW"
fi
at -M -f "${HOME}/bin/crawl-dagpris.sh" "${scheduled_time}"
- 36
This worked for me (thanks), but I didn't use the last step given in the answer:
Then add the following line to your
~/.profile:
I'm using Ubuntu Studio 12.10 Quantal and in my case instead of that last step I put that one liner here: “Applications Menu” → “Settings” → “Settings Manager” then in the Settings Manager under “Session and Startup” then the “Application Autostart” tab.
This is for those of us that are GUI users, because ~/.profile is only sourced by bash when it starts a log-in interactive shell (even ~/bashrc is not so useful since that is only sourced when bash is starting an interactive shell).
- 8,436
- 1
