When i do upgrade or install, im getting this error.
srikanth@btp8sa42:~/projects/raff$ sudo apt-get upgrade
[sudo] password for srikanth:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 libcurl3-gnutls : Depends: libc6 (>= 2.15) but 2.13-20ubuntu5.3 is installed
               Depends: libgnutls26 (>= 2.12.6.1-0) but 2.10.5-1ubuntu3.2 is installed
               Depends: libgssapi-krb5-2 (>= 1.10+dfsg~) but 1.9.1+dfsg-1ubuntu2.3 is installed
 libp11-kit0 : Depends: libc6 (>= 2.14) but 2.13-20ubuntu5.3 is installed
E: Unmet dependencies. Try using -f.
When i do "apt-get -f install"
srikanth@btp8sa42:~/projects/raff$ sudo apt-get -f install
Correcting dependencies... failed.
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
How can i fix this?
Oyibo
  • 1,917
This has solved the problem.
Doing a
apt-get install libp11-kit0/oneiric libcurl3-gnutls/oneiric
fixed this.
