A few weeks ago my chromebook got crazy and its OS got corrupted for an unknown reason. I'd like to instal Ubuntu 12.04 64bit on it using a bootable USB pendrive, but since it is not the usual installation that I am used to on PCs/laptops....I am a bit stuck and dont even know where to start. I'd simply like to make a pendrive that I can make bootable for my chromebook and do the installation.
Jorge Castro
  • 73,717
Elysium
  • 11,142
There are two ways - one requires the Chrome OS to be present and utilizes the kernel there, but you can't do it from a bootable USB stick. The other way involves flashing a new BIOS - but again, you have to be in a workable Chrome OS session. I think the BIOS flash tool got pulled by its creator and is hard to find. But either way, you will need to restore Chrome OS. There is a recovery to do this -
Recover to stock cr48
Once its recovered, just google for the cr48 BIOS to install from a pen drive - good luck.
Installing ubuntu on chromebook is a difficult task as far as I know.
It require turn on the developer option & using custom linux kernel.
Few guides are available in internet
http://liliputing.com/2012/11/how-to-install-ubuntu-12-04-on-the-199-acer-c7-chromebook.html
http://chromeos-cr48.blogspot.in/2012/04/chrubuntu-1204-now-with-double-bits.html
Web-E
  • 21,716
This is a very easy to follow step by step guide to turn the new $249 Samsung Chromebook into a full featured netbook by installing Ubuntu Linux. Once complete you can have a dual boot Samsung Chromebook with ChromeOS one one SSD drive and Ubuntu 12 on the other SSD drive.
http://techfoobar.blogspot.com/2013/01/how-to-install-ubuntu-on-samsungs-new.html"
Sloan
The way I have installed Ubuntu on a Chromebook is by using Crouton.
  1. Enter developer mode.
  2. At the scary boot screen press Ctrl+D
  3. It will take a while to start up. Enter your Google information.
  4. Click on this download link: https://goo.gl/fd3zc and save the file to your Downloads folder. In case this link has become obsolete, you can find the latest link to the same file at this webpage: GitHub dnschneid/crouton - Chromium OS Universal Chroot Environment.
  5. Press the keyboard combination Ctrl+Alt+T
  6. Type shell and hit Enter.
  7. Run the following command:
    sudo sh -e ~/Downloads/crouton -r trusty -t unity
karel
  • 122,292
  • 133
  • 301
  • 332
