I am new to Ubuntu and linux as well, the thing is... I got strange problem with my laptop, I am not sure is the problem with my hardware or the os
I got: Dell Studio 15 (ATI Graphics Card) with Ubuntu 12.10_64bit version installed
Issue is... when I suspend(sleep) the laptop either by command or by turning the flap off, it does suspend perfectly, but when I wakes it up, It starts and after few minutes around 15-20 it turns off automatically, after reproduction of the error,
I realize that the fan is not starting after waking up the laptop, so the laptop starts but not the fan so, it shut down when it gets overheated,
can anyone please, help me with this, or show me how to solve this issues. Thanks Nixit Patel
most probably installing the correct VGA driver can reduce overheating. To install correct VGA driver
you need to do some simple things if your using ubuntu 12.10
  1. first go to software center and type drivers.
  2. in there find additional drivers. and install it.
  3. after installation complete open it. it will search drivers for your VGA card. warning! do not close it. because additional drivers not working properly in 12.10 so once you close you cannot find it anywhere. then you must remove it and re-install it again through software center.
  4. install all available VGA drivers for your machine.
  5. after installation complete it will ask you to restart. you done!.
  6. after restart go to Settings > Details there you can see your VGA name and type.
farhan
  • 352
Take a live ubuntu/Other OS pendrive try to boot from that and see if that's the case hmm the best would be if you have second OS installed on the same laptop where you can identify it is with ubuntu or the system , fan normally works when cpu sensor reports temperature but above i guess is the fast way to get started isolating the issue.
Ali
  • 41
Patel hope this link helps you , this is pointing to install Orignal driver from Chip manufacturer /hardware vendor website rather then generic please find the link below.
Laptop shuts down upon waking from suspend
Ali
  • 41
