When I enter sudo apt-get upgrade, this message shows up:
dpkg: error: cannot scan updates directory `/var/lib/dpkg/updates/': No such file or directory
E: Sub-process /usr/bin/dpkg returned an error code (2)
Any Help ?!
Any Help ?!
This may work.
sudo dpkg --clear-avail
sudo apt-get update
It may also not. You also need to check your file system for errors, and make sure your only using repos that are for your version of Ubuntu.
I would start with the above commands, then if that still doesn't work, have a look here for restoring your apt database.
You can also try (very dangerous)
sudo mv /var/lib/dpkg/updates /root/
sudo apt-get update
sudo mkdir /var/lib/dpkg/updates
sudo chmod 755 /var/lib/dpkg/updates
Assuming you're back on track you can then remove the copy of updates in /root/updates
