I am new to Linux. I have a Dell Inspiron 15 with a 1st generation Intel Core i3 and Ubuntu 12.10.
My laptop gets heated quickly which doesn't happen on Windows. Also the battery is discharged faster than in Windows. Please help.
Glutanimate
  • 21,763
john
most probably installing the correct VGA driver can reduce overheating. To install correct VGA driver
you need to do some simple things if your using ubuntu 12.10
  1. first go to software center and type drivers.
  2. in there find additional drivers. and install it.
  3. after installation complete open it. it will search drivers for your VGA card. warning! do not close it. because additional drivers not working properly in 12.10 so once you close you cannot find it anywhere. then you must remove it and re-install it again through software center.
  4. install all available VGA drivers for your machine.
  5. after installation complete it will ask you to restart. you done!.
  6. after restart go to Settings > Details there you can see your VGA name and type.
farhan
  • 352
Most probably, it is due to having several graphic cards enabled simultaneously, usually intel + (Nvidia | ATI). I have this same problem.
You can try to disable one of the graphic cards. You could find additional information in this blog dedicated to Linux hybrid graphics.
jap1968
  • 394
-2
This is kernel issue. You can reinstall a kernel of your choice through SW manager in ubuntu. I faced the same problem with ubuntu in my laptop and fixed it by reinstalling the same karnel that RHEL 6.4 uses. Hope the same will work fine for you.
