64
How can you quickly get the complete path to a file for use in terminal?
7 Answers7
65
readlink -f foo.bar
or (install it first)
realpath foo.bar
Avinash Raj
  • 80,446
spennig
  • 814
41
Just drag and drop the file in the terminal.
13
All good answers; Here is a tip for another situation.
If you are browsing your files using nautilus and you want the complete path of your current directory, then press CTRL+L. This changes the breadcrumb buttons temporarily back to the old-style address bar, allowing you to copy the path.
Sicco
  • 411
If it's an executable, then execute (in a terminal):
$ which your_executable
For example: $ which ls
Matt
  • 107
perseo22
  • 1,056
In addition to dragging the icon, there are a few ways to get the full path without nautilus (or thunar, konqueror, et al.). You would then triple-click or click-drag and copy, potentially saving this in your clipboard manager*, and paste it where you need.
(pastie, klipper, glippy, glipper, anamnesis)
  • You can use find in a directory above your file. (If you don't know where it is, start where your shell drops you, [generally] in the top of your home directory.)
    find . | egrep filename
  • You can use locate to get the filename. (Run sudo updatedb if that hasn't been done recently.)
A more realistic example of using find would be something like :
$ find | egrep askubuntu | grep txt
./askubuntu-temp.txt
./drDocuments/web/meta.askubuntu.txt
./other/stuff/askubuntu.txt.iteration.1
./other/stuff/askubuntu.txt.iteration.2
To cut out the ones you don't like, e.g.:
find | egrep askubuntu | grep txt | egrep -v iteration
find | egrep askubuntu | grep txt | egrep -v 'iteration|meta|other'
locate is used much the same way, though grep is frequently more necessary:
locate myfile | egrep home | egrep -v 'mozilla|cache|local|bin|\.pyc|test' | grep \.py
This isn't the most efficient way to type this, but usually if I've lost a file, I do this iteratively, adding grep clauses as I go.
belacqua
  • 23,540
Easily done in python using os.realpath() function:
$ python -c 'import os,sys;print(os.path.realpath(sys.argv[1]))' ./VirtualBox\ VMs/
/mnt/HDD/VirtualBox VMs
From a related answer,you can also use readlink
$ readlink -e ./out.txt
/home/username/out.txt
If you simply copy a file in Nautilus, then the full path is copied.
Then paste it in the terminal. By simply pasting you get:
file:///home/juan/2017/agenda20170101.html
If you right-click and choose "Paste filenames" then you get:
'/home/juan/2017/agenda20170101.html'
with the quotes as shown.
This differs from Windows, that copies the file content instead of its name.
Juan Lanus
  • 201
