Note: I just went around looking for MUD server with NAGS game library and found this: nags-php-mud. My answer is irrelevant if you are using something else.
The config.php had the following config:
/*Modify the setting here to set up your game server */
$configarray = array(
'DB_HOST' => 'localhost',
'DB_USERNAME' => 'nags',
'DB_PASSWORD' => 'password',
'DB_DATABASE' => 'nags',
'IP_ADDRESS' => '0.0.0.0',
'SERVER_PORT' => '4000',
'SERVER_NAME' => 'NAGS GAMING SYSTEM',
So the port number is 4000. Can you try updating the IP Address to 127.0.0.1 then connecting to port 4000 using telnet: telnet 127.0.0.1 4000
Updated
In the above command, you have telnet localhost and not telnet localhost 4000.
I tried running it but I am getting some issue. It displays the following and I am unable to trace it:
PHP Notice: Undefined index: quiet in /home/blvdeer/Downloads/nags-php-mud-master/nags.php on line 34
PHP Notice: Undefined index: q in /home/blvdeer/Downloads/nags-php-mud-master/nags.php on line 34
PHP Notice: Undefined index: deamon in /home/blvdeer/Downloads/nags-php-mud-master/nags.php on line 38
PHP Notice: Undefined index: d in /home/blvdeer/Downloads/nags-php-mud-master/nags.php on line 38
PHP Notice: Undefined property: MAIN::$MESSAGE in /home/blvdeer/Downloads/nags-php-mud-master/modules/main.php on line 158
SYSTEM: (LOAD MODULE) MESSAGE
SYSTEM: (LOAD MODULE) CONFIGURE
SYSTEM: (LOAD MODULE) DATABASE
