Ubuntu uses a DNSMasq instance for Network Manager starting in 12.04 - how can I disable it?
Edit /etc/NetworkManager/NetworkManager.conf with the following command:
gksu gedit /etc/NetworkManager/NetworkManager.conf
Enter in your password when prompted.
Comment out the line dns=dnsmasq, so it looks like this:
#dns=dnsmasq
and then restart Network Manager with
sudo restart network-manager
# if you get /com/ubuntu/upstart: Connection refused, try:
sudo service network-manager restart
Ta-da! You're all set!
- 336
- 2
- 14
- 61,707
I also had this problem, but I'm on Ubuntu 16.04, so the original solution did not work. However, this page had the solution.
Add DNSStubListener=no in /etc/systemd/resolved.conf and then restart the systemd-resolved service. Now, the built-in dnsmasq should not start automatically.
You will also need to make sure that dns=dnsmasq is commented out in /etc/NetworkManager/NetworkManager.conf, like the previous answer specifies.
- 29
If this still does not work for you, like was my case with Ubuntu 16.10. Then check who is using this port with:
lsof -i :53
And if you for example have "systemd-r", then you have to stop the service with:
sudo service systemd-resolved stop
- 72,312
