30
For development purposes I want all DNS requests to the .dev TLD to forward to my own PC.
The hosts file does not suffice. I use multiple domains and also multiple subdomains. I would have to add a line for each combination.
I have read that a DNS forwarder like DNSmasq can be used to do the job (for example as described here). Also this software is already installed on Ubuntu 12.10.
The problem is that I fail to see how and where I should configure DNSmasq, i.e., where I should put this line:
address=/dev/127.0.0.1
Braiam
  • 69,112
In Ubuntu 12.10 or later you can do this with dnsmasq as run by NetworkManager.
  1. Create the directory mkdir /etc/NetworkManager/dnsmasq.d if it doesn't already exist.
    sudo mkdir /etc/NetworkManager/dnsmasq.d
  2. Toss the following line into /etc/NetworkManager/dnsmasq.d/dev-tld.
  3. (Ubuntu 12.10) Restart NetworkManager.
    sudo service network-manager restart
  4. (Ubuntu > 13.04) Restart Dnsmasq.
    sudo service dnsmasq restart
  5. Enjoy the awesomeness.
Thomas Ward
  • 78,878
jrg
  • 61,707
18
The complete standalone dnsmasq (DHCP and DNS server) is not installed by default in Ubuntu 12.04 and 12.10, but a package called dnsmasq-base is installed by default in Ubuntu Desktop 12.04 and 12.10. The dnsmasq-base package contains the dnsmasq binary and is used by NetworkManager.
To do what you want you will need to use dnsmasq as a caching DNS server. You need to:
  • Install dnsmasq sudo apt-get install dnsmasq
  • Change your network setting, so that your computer uses itself as it dns server.
  • Make the changes to the config files:
Create /etc/dnsmasq.d/dev-tld with these contents:
local=/dev/
address=/dev/127.0.0.5
The first command says *.dev requests can't be forwarded to your real DNS server. The second says *.dev resolves to 127.0.0.5 which is localhost.
  • Restart the dnsmasq service (not network-manager)
r3m0t
  • 103
Javier Rivera
  • 35,434
Just installed a fresh 19.04 and the only way I got it working was disabling systemd-resolved and have NetworkManager use dnsmasq instead for DNS. NetworkManager has built in support for dnsmasq and dnsmasq-base package is installed by default.
I am pointing multiple domains to different VMs like *.customerX.test to 192.168.33.10 and *.productY.test to 192.168.33.20 and so on. I would not use *.dev anymore but instead one of the reserved top level domains.
Solution
  1. Disable systemd-resolved
     sudo systemctl disable systemd-resolved.service
     sudo systemctl stop systemd-resolved.service
     sudo rm /etc/resolv.conf
  2. Edit /etc/NetworkManager/NetworkManager.conf to use dnsmasq for DNS.
     [main]
     dns=dnsmasq
  3. Put dnsmasq configuration in /etc/NetworkManager/dnsmasq.d/test-tld.conf
     address=/test/127.0.0.1
     address=/customerX.test/192.168.33.10
  4. and finally restart NetworkManager which will generate a new /etc/resolv.conf
     sudo systemctl restart network-manager.service
domo
  • 1,273
The following worked worked for me in Ubuntu 16.04:
  1. Install dnsmasq
    sudo apt-get -y install dnsmasq
  2. Edit dnsmasq.conf file:
    sudo nano /etc/dnsmasq.conf
  3. Add your command:
    For wild card (*) then you can use dot (.) then dnsmasq to resolve WHATEWER_YOU_PUT_HERE.yourmachine.yourdomain to the same ip. E.g., address=/.localhost.dev/127.0.0.1
  4. Restart dnsmasq service:
    sudo /etc/init.d/dnsmasq restart
Jeril
  • 378
