-1
Possible Duplicate:
How to roll back Ubuntu to a previous version?
I installed 12.10 removing Windows XP on a Netbook. The installation was successfully but the system is working too slow.
I have tried to reformat the drives so I can downgrade but none of the reinstalls (12.04 & 11.10) worked.
All I want to do is start again, clean the whole hard drive so there is no trace of 12.10 to enable a fresh install of 11.10 (I believe this works fine with my netbook specs) or even Windows XP.
I don't know where to start!
just make a bootable usb and install 11.10 you don't have to do anything more.
actually make a bootable usb for 12.04 and then boot with the live-cd. and choose the install option where you "install and use the whole hdd", so that you get a fresh start. 11.10 will only be supported until April 2013, therefor I suggest to install 12.04 because it's the current LTS.
Yes You can install windows but you must reinstall grub afterwards.
Alvar
  • 17,038
