Paste shortcuts, or perhaps create a link to another folder from a folder, or any thing of the sort.
I need to do this because I want to crate a link from other directories to my music folder, so that Rhythmbox can update its libraries like that. I am also asking if it is a good way for adding music to Rhythmbox's library. I am quite new to this, please pardon if the question meets the foolishness criteria. :|
Thanks in advance!
You can do it in Nautilus (the equivalent of Windows Explorer) within Ubuntu.
Let's say you want to make a shortcut of
/home/your_name/source_folder
inside another folder called
/home/you_name/dest_folder
1. Drag and drop
Hold down Ctrl+Shift and drag the source_folder with the Left mouse button into the dest_folder.
2. Right Click Menu
Right click on the source_folder and choose Make Link. A new folder called "Link to source_folder" will be created in /home/you_name/ and you can move it inside dest_folder and rename the link to what you want.
user68186
  • 37,461
You can do it from the Termnial:
ln -s /home/your_name/source_folder /home/you_name/dest_folder
Ed Manet
  • 966
Right click the folder you want to link to, select Make Link. A link to the that folder will be created, and you can copy it to the music folder, or wherever within the filesystem.
PS: Apologies, if it's not like in Windows, not sure how it's done there.
mikewhatever
  • 33,013
If you have a Mouse with 3 buttons (or a pressable mouse wheel) you can drag and drop the file/folder with the 3rd button pressed. Alternatively, hold down the "Alt"-Key while dragging. A pop-up menu will give you options whether you want to link, move or copy.
(That is for Unity and Gnome. KDE might be different.)
EDIT:
I just played around a little. When you press "Shift+CTRL" while you drag, it will crate a link. The mouse pointer indicates which action will be taken (a small plus next to it means copy, a knot for a link)
