I've installed Ubuntu 12.10 on a Lenovo Y500 laptop (2012), video card is Nvidia 650M (no integrated graphics), I'm using driver 310.19. The problem is that I can't adjust brightness at all. If I press the relevant media keys, the indicator in ubuntu works correctly but the brightness is not changed.
So far I've tried the following:
Editing xorg.conf in this way:
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    Option         "RegistryDwords" "EnableBrightnessControl=1"
EndSection
Adding the options acpi_osi=linux acpi_backlight=vendor to the grub boot options
Setting brightness from the terminal and using xbacklight. The values of /sys/class/backlight/acpi_video0/brightness can be changed as well but the brightness remains the same.
Do you have any other hints?
Solution
It is possible to enable the backlight by installing the nvidiabl module. First of all install git and dkms:
$ sudo apt-get install git dkms
Download the code on your machine and compile the package:
$ git clone https://github.com/guillaumezin/nvidiabl.git
$ cd nvidiabl
$ sudo make dkms-install
Now the module should be installed. To activate the nvidiabl module you should issue the command:
$ sudo modprobe nvidiabl
Now the directory /sys/class/backlight/nvidia_backlight/ should be present. In order to manually change the brightness you have to write in the brightness file:
$ sudo su
# echo 100 > /sys/class/backlight/nvidia_backligh/brightness
You can substitute 100 with any value up to 127. In my case not the complete range of backlight are supported. You can tune the brightness calibration by varying the min and max parameters (you will still have to write values in brightness up to 127):
$ sudo modprobe -r nvidiabl
$ sudo modprobe nvidiabl max=100000 min=10
You can load the module at startup by adding nvidiabl (with or without max and min parameters) to the file /etc/modules, but I still haven't figured out how to properly add hotkeys.
pygabriel
  • 131
5 Answers5
I installed Xubuntu 12.10 on my new Lenovo Y500 and also could not adjust brightness, it was at at maximum and could not be controlled. Get installed and used graphics driver:
lshw -c video
Gave me:
configuration: drigver=nouveau latency=0
  • changing the value in /sys/class/backlight/acpi_video0/brightness does not change brightness
  • booting with acpi_backlight=vendor does not change brightness
  • etpci -s 00:01.0 F4.B=XX (XX = 00 to ff) does not change brightness
For the moment I solved this by installing the nvidia driver:
sudo apt-get install linux-source
sudo apt-get install linux-headers-generic
sudo apt-get install nvidia-current-updates
This gives you the terminal command:
sudo nvidia-settings
Go to: DFP-0-(LGD), Tab: Color Correction
Here you can set the brightness.
mrcktz
  • 1,774
peterpm
  • 39
Add this to grub:
Eric Carvalho
  • 55,453
I am using xbacklight you can install it with: sudo apt-get install xbacklight xbacklight use-help for saver as used, is very simple to use, you can assign any key convinacion ami I worked until you install some nvidia driver you can install it manually by downloading the driver from the nvidia official website as follows: ctrl + alt + f1 LightDM stop sudo service sudo chmod + x NVIDIA.run sudo. / NVIDIA.run
if there is some error with the nouveau driver, select that whether or accept restart the computer and re-run the NVIDIA.run
or repositories THROUGH for ubuntu 13.04 or 12.10: sudo apt-add-repository ppa: xorg-edgers/ppa for ubuntu 12.04: sudo apt-add-repository ppa: ubuntu-x-swat/x-updates
sudo apt-get update sudo apt-get install nvidia-current nvidia-settings
I dunno if this is helpful to anyone at all, but I've come across this post several times looking for help with my Y500.
I'm running mint cinnamon 17 and I have the GT 750M, with the NVIDIA drivers. All I needed to do was install xbacklight and set my keyboard bindings for the function keys to xbacklight -inc 10 and xbacklight -dec 10.
klaami
To resolve the brightness problem on a Lenovo Y500 you should to do the following:
1. In the file "/etc/default/grub" you need to change following string:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
2. Reboot your laptop!
3. Now you can change the brightness of display with following command (for example we want to set 30% of brightness):
echo 30 > /sys/class/backlight/nv_backlight/brightness
4. If you want configure the brightness automatically during booting OS you need the following. After selecting a suitable brightness, add the following command to /etc/rc.local (for example if you have chose 30% of brightness):
I have tested this on my Lapton Y500, GeForce GT 750M (Ubuntu 14.04)
zh_
