16
Problem with this file /tmp-air-nkhvxz-setup-error-while-loading-shared-libraries-libgtk-x11-2-0-so-0
I try to solve this problem and try to install libgtk-x11-2.0.so.0
sudo apt-get install libgtk2.0-0:i386
sudo apt-get install ia32-libs
but two links above do not work. Is there any other alternative one?
Braiam
  • 69,112
I have the same problem and I was unable to fund solution on the internet, nothing worked for me. Finally I've managed it to work simply by installing libgtk2.0-0:i386 graphic library from the Ubuntu Software Center.
You can also type the following command in a terminal:
PhoneixS
  • 671
To fix this issue. You must install ia32-libs-gtk, which is a virtual package of ia32-libs. Also try installing libglib2.0-dev
sudo apt-get install ia32-libs libglib2.0-dev
If the above did not work then try installing
The shared library you mentioned belongs to libgtk2.0.0. So the above command should solve the issue.
If you are running 64 bit Ubuntu, try
This worked in 14.04 LTS
devav2
  • 37,290
-1
You need to install some libraries:
sudo apt-get install libgtk2.0-0:i386 libnss3-1d:i386 libnspr4-0d:i386 lib32nss-mdns libxml2:i386 libxslt1.1:i386
Richard
  • 8,588
