You can install the Reliance Netconnect software in Ubuntu. Just follow these steps and you will get connected:
Connect your dongle and open the drive which you can see in your Launcher. You can see various files including Windows installer etc.
Copy the Linux folder and install_linux file from your dongle. These files will be stored in your dongle.
Create a folder in Desktop. For easy access, name it as Reliance-Linux. Copy the above two files and paste it into Reliance-Linux folder in Desktop.
Open Gedit and paste the following code:
#!/bin/bash
CURRENT_PATH=`echo $0|sed 's/autorun.sh//'`
"${CURRENT_PATH}"/install_linux
save the file as autorun.sh in Reliance-Linux folder which you had created.
Now open the terminal and type the command sudo -i. Enter your password if prompted.
Then you have to cd to Desktop and install the Reliance Netconnect software as
cd ~/Desktop/Reliance-Linux
chmod +x ./install_linux
./install_linux
After installation is complete Search for Reliance Netconnect in Dash.
Keep surfing!!
[Note: step 4 is optional if autorun.sh is already present in Linux folder of your dongle]
For dongles like Airtel 3G & MTS, the method is the same.
