Here I join the multitude of "Nvidia error" questions, because I couldn't find anything that helped.
Background: For some reason my drivers (nvidia-experimental-310) stopped working, so I tried re-installing them. Also, the same thing happened when I tried installing nvidia-current-updates. Here's the log:
$ sudo apt-get install nvidia-experimental-310
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 1 to remove and 0 not upgraded.
Need to get 0 B/37.4 MB of archives.
After this operation, 1,758 kB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 221035 files and directories currently installed.)
Removing nvidia-current-updates ...
Removing all DKMS Modules
Done.
update-alternatives: using /usr/lib/i386-linux-gnu/mesa/ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) in auto mode
INFO:Disable nvidia-current-updates
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Processing quirk ThinkPad T420s
DEBUG:Failure to match Dell Inc. with LENOVO
DEBUG:Quirk doesn't match
DEBUG:Processing quirk Latitude E6530
DEBUG:Failure to match Dell DXP051 with Latitude E6530
update-initramfs: deferring update (trigger activated)
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Processing triggers for man-db ...
Processing triggers for initramfs-tools ...
update-initramfs: Generating /boot/initrd.img-3.7.0-7-generic
Selecting previously unselected package nvidia-experimental-310.
(Reading database ... 220868 files and directories currently installed.)
Unpacking nvidia-experimental-310 (from .../nvidia-experimental-310_310.14-0ubuntu1_i386.deb) ...
Processing triggers for desktop-file-utils ...
Setting up nvidia-experimental-310 (310.14-0ubuntu1) ...
update-alternatives: using /usr/lib/nvidia-experimental-310/ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) in auto mode
update-alternatives: warning: skip creation of /usr/lib32/libOpenCL.so because associated file /usr/lib32/nvidia-experimental-310/libOpenCL.so (of link group i386-linux-gnu_gl_conf) doesn't exist
update-alternatives: warning: skip creation of /usr/lib32/vdpau/libvdpau_nvidia.so.1 because associated file /usr/lib32/nvidia-experimental-310/vdpau/libvdpau_nvidia.so.1 (of link group i386-linux-gnu_gl_conf) doesn't exist
update-alternatives: warning: skip creation of /usr/lib32/libvdpau_nvidia.so because associated file /usr/lib32/nvidia-experimental-310/vdpau/libvdpau_nvidia.so (of link group i386-linux-gnu_gl_conf) doesn't exist
update-alternatives: using /usr/lib/nvidia-experimental-310/alt_ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) in auto mode
INFO:Enable nvidia-experimental-310
Loading new nvidia-experimental-310-310.14 DKMS files...
Building only for 3.7.0-7-generic
Building for architecture i686
Building initial module for 3.7.0-7-generic
Traceback (most recent call last):
File "/usr/share/apport/package-hooks/dkms_packages.py", line 22, in <module>
import apport
ImportError: No module named apport
Error! Bad return status for module build on kernel: 3.7.0-7-generic (i686)
Consult /var/lib/dkms/nvidia-experimental-310/310.14/build/make.log for more information.
So there's some "apport" error going on, whatever that means. Here's the make file log: http://paste.ubuntu.com/1464536/
Question: How do I solve this?
Additional Info:
- Xubuntu 12.10
- Nvidia GeForce GT430
If more info is needed, just let me know.
Update:
I removed the Xorg-edgers ppa, and uninstalled all the 3.7 kernel things using synaptic. Then I ran apt-get autoremove to remove any leftovers, apt-get update, and the apt-get install nvidia-current-updates, which still didn't work. Looking at the log from terminal, it seems that I don't have the source of the kernel or something.
