I'm running into the following error when I'm installing any package on 12.04.
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 postgresql-client-9.1 : Breaks: postgresql-9.1 (< 9.1.7-0ubuntu12.04) but 9.1.6-1~precise2 is installed
E: Unmet dependencies. Try using -f.
Tried following commands,
sudo apt-get autoremove
sudo apt-get autorclean
sudo apt-get install -f
sudo apt-get purge postgresql
sudo apt-get purge postgresql-client-9.1
sudo apt-get autoremove --purge postgresql-client-9.1
sudo apt-get remove --dry-run postgresql
sudo apt-get update
etc. But none of this could save me. Any idea?
Eliah Kagan
  • 119,640
sjn
  • 151
I had a similar problem , and this solved it.
add-apt-repository ppa:pitti/postgresql
apt-get purge postgresql*
apt-get install update && apt-get install upgrade
apt-get install postgresql
apt-get update && apt-get upgrade
Nishant
  • 111
Got rid of these error by removing those Postgresql (and client-9.1) using 'dpkg -r' directly.
sudo dpkg -r postgresql
sudo dpkg -r postgresql-client-9.1
sjn
  • 151
I had this problem which was a result of version incompatibility between binaries in the standard Ubuntu repository and in pitti. I resolved it by removing postgresql-client metapackage. Hope this helps.
Aditya
  • 13,616
