Following the instruction found here I have attempted to build this driver.
Some information about my laptop computer:
Toshiba Satellite S855-S5254
8 GB RAM
Intel i7-3610QM CPU 2.30 GHz
Ethernet - Atheros AR8161/8165 PCI-E Gigabyte ethernet controller
Wireless - Realtek RTL8723AE Wireless LAN 802,11n PCI-E NIC
64 Bit windows 7 OS installed
64 Bit Ubuntu Desktop 12.10 installed
A quick note, I have been using a USB wireless NIC to download files as necessary and then I remove it when it is not needed.
What I am getting is as follows:
I first get the following using this syntax:
sudo apt-get install build-essential linux-headers-generic linux-headers-uname -r
Which results in the following:
Reading package lists... Building dependency tree... Reading state information... build-essential is already the newest version. linux-headers-3.5.0-17-generic is already the newest version. linux-headers-generic is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 220 not upgraded.
This was the second time I had executed the above syntax because I was not sure it had completed correctly.
Not sure as to if things were going correctly I then went to retrieve the driver tarball an extract it using the following:
wget -O- http://dl.dropbox.com/u/57056576/DRIVERS/REALTEK/rtl_92ce_92se_92de_8723ae_linux_mac80211_0006.0514.2012.tar.gz | tar -xz
I do believe all went well with this for all the files are there as listed in the archive listing, I then excute the make command with the following results:
cd realtek make
make -C /lib/modules/3.5.0-17-generic/build M=/home/slalonde/realtek modules
make[1]: Entering directory /usr/src/linux-headers-3.5.0-17-generic'
CC [M] /home/slalonde/realtek/base.o
make[1]: Leaving directory/usr/src/linux-headers-3.5.0-17-generic'
And then I do the make install with the following results:
I the check to see if the driver is there using the following:
sudo modprobe rtl8723e
FATAL: Module rtl8723e not found
So as you can see I am not having much success. Any help would be appreciated.
