110
While playing with awk I came to execute:
ls -la >> a.txt ; awk {'print $5  $1'} a.txt ;
This is giving output like:
53277-rw-------
52347-rw-------
How can I get a space between these two friends of output?
muru
  • 207,228
Raja G
  • 105,327
  • 107
  • 262
  • 331
5 Answers5
135
Just change the line to
ls -la >> a.txt ; awk {'print $5 "        " $1'} a.txt ;
this should print the output with spaces.
Hope this helps.
Edit:
As suggested by McNisse you can use printf, which would provide you good output format
ls -la >> a.txt ; awk {'printf ("%5s\t%s\n", $5, $1)'} a.txt ;
devav2
  • 37,290
104
Another awk-specific technique, use the "output field separator"
ls -la | awk -v OFS='\t' '{print $5, $1}'
The comma is crucial here.
glenn jackman
  • 18,218
29
A simple way to get tabs is:
awk {'print $5"\t"$1'}
a06e
  • 14,233
I know this is an old thread, but I'm just learning and found these posts helpful. My best solution was to use gawk to insert spaces between the variables for you.
ls -la | gawk '{print $1, $9}'
To place the space between the arguments, just add " ", e.g. awk {'print $5" "$1'}.
However it is not recommended to parse output of ls command, since it's not reliable and output is for humans, not scripts. Therefore use alternative commands such as find or stat.
Here is example using GNU stat:
$ stat -t *
001.txt 23 8 81a4 501 20 1000004 242236402 1 0 0 1460260387 1460260239 1460260239 1460260194 4096
7c1c.txt 21 8 81a4 501 20 1000004 242236595 1 0 0 1460261322 1460260486 1460260486 1460260486 4096
which will print you machine-friendly output (in terse form), so you can get exactly what you need. Then use -c to use specific format, or use awk, cut or read to get the right columns.
Check stat --help for further options. For example to print day of modification, check this example.
kenorb
  • 10,944
