68
Situation: If I entered a copy command like cp -rf /src/ /dsc/ then I am waiting several minutes for copy large directories. I forgot to put -v flag to verbose an output, Can I do it during copying?
muru
  • 207,228
Smile.Hunter
  • 8,705
5 Answers5
138
This question seems to be old, but for the cp command you've got the --verbose option.
So the command works as follows:
cp --verbose -rf /src/ /dsc/
grooveplex
  • 2,506
  • 27
  • 35
myolli4
  • 1,489
46
No you can't, but you could use the watch command to look at the destination directory to see how the process is progressing, eg.
watch ls -l /dsc/
fabricator4
  • 8,471
  • 37
  • 39
17
You could always use rsync instead, you'll atleast get to see the files that are being copied
rsync -rva /src/ /dst/
Of-course this only works before you start copying as an alternative to cp. The good news is though that rsync will only copy the files it needs to so you can kill your long-running cp command run the rsync command and it will pick up where cp left off.
kiiadi
  • 271
I propose :
watch du -sh /dsc/
odile
  • 81
I recommend to use Midnight Commander in case when you need to see a progress of files copying.
  1. Install Midnight commander:
    apt-get install mc
  2. Open it:
    mc
  3. On first panel open source, on second - destination. Start copying using "F5".
MC will display nice and informative progress dialog.
