I have download the QQ2012's deb in downlaod files, but when I install the deb, system tell me:
$ sudo dpkg -i wineqq2012-20120719-longene.deb
[sudo] password for collins:
dpkg: error processing wineqq2012-20120719-longene.deb (--install):
 cannot access archive: No such file or directory
abu_bua
  • 11,313
Collins
  • 71
The error message No such file or directory means that the .deb file does not exist, or does not exist in the current directory.
The ~ between : and $ in the prompt represents the current working directory. ~ (when the next character is a / or, as in this case, nothing at all) is shorthand for your home directory, /home/collins.
You said you downloaded the .deb file "in download files." Assuming this means you downloaded it to your Downloads folder, that means it's located in /home/collins/Downloads rather than /home/collins.
So you should be able to install it by running this command:
sudo dpkg -i ~/Downloads/wineqq2012-20120719-longene.deb
If that doesn't work, try typing
sudo dpkg -i
without pressing Enter. Add a space to the end. Then drag the file from Nautilus (the file browser) into the Terminal window. That will paste its full path. Then press Enter.
Eliah Kagan
  • 119,640
I think you are running the command from a different directory.
Open Terminal (Ctrl+Alt+T) and make sure that the file you trying to run is listed when you do the ls command.
If you have downloaded the file using a web browser browser, then the file should be located in ~/Downloads. Change the directory to your downloads folder with cd ~/Downloads.
Once you have made sure that ls lists the file, then run the command:
Eliah Kagan
  • 119,640
devav2
  • 37,290
Modify the command the following way:
sudo dpkg -i ./wineqq2012-20120719-longene.deb
This will make dpkg search the package in the current folder.
BTW, you should you use apt, to get the pkg listed in the log files, and more:
sudo apt install ./wineqq2012-20120719-longene.deb
abu_bua
  • 11,313
