I want to install BSNL EVDO Rev A USB Data Card Model No.:T-U500 on my laptop which is double booted with both ubuntu and windows 7. BSNL evdo works well on windows 7 and I tried to install it on ubuntu.
I don't have internet connection in Ubuntu.
I tried to install using terminal
at@at-Presario-V3700-Notebook-PC:~$ sudo modprobe usbserial vendor=0x15eb product=0x7153
at@at-Presario-V3700-Notebook-PC:~$ sudo wvdialconf
Editing `/etc/wvdial.conf'.
Scanning your serial ports for a modem.
Modem Port Scan<*1>: S0   S1   S2   S3   S4   S5   S6   S7
ttyUSB0<*1>: ATQ0 V1 E1 -- and failed too at 115200, giving up.
Sorry, no modem was detected!  Is it in use by another program?
Did you configure it properly with setserial?
Please read the FAQ at http://alumnit.ca/wiki/?WvDial
TWO: Then I tried to follow http://linuxers.org/howto/how-configure-bsnl-evdo-linux
And after I typed wvdial I am getting error /etc/wvdial.conf I edited to:
[Dialer Defaults]
Modem=/dev/tty0
Baud=115200
Dial Command = ATDT
Baud=115200
Dial Command = ATDT
init1=ATZ
init2=AT+CRM=1
Flow Control= Hardware (CRTSCTS)
Username = 9180326472
Password = 9180326472
Phone = #777
Stupid Mode = 1
resolv.conf I edited to
hash Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
hash   DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 218.248.240.181
nameserver 208.67.220.220
(By hash I mean #)
What I typed in terminal:
root@at-Presario-V3700-Notebook-PC:~# vim /etc/wvdial.conf root@at-Presario-V3700-Notebook-PC:~# vim /etc/resolv.conf root@at-Presario-V3700-Notebook-PC:~# wvdial --> WvDial: Internet dialer version 1.61 --> Cannot get information for serial port. --> Initializing modem. --> Sending: ATZ --> Sending: ATQ0 --> Re-Sending: ATZ --> Modem not responding. root@at-Presario-V3700-Notebook-PC:~#
After doing all this I logged into Windows, uninstalled it, unplugged the modem, plugged it again, clicked "open folder to view files", clicked Linux, Copied "BSNL EVDO Installer" to the desktop. Then I logged onto Ubuntu moved the file into its desktop and installed it. After installation I clicked "EVDO Data Card" but nothing happened. What should I do? Is the problem caused by something I did above?
Braiam
  • 69,112
chndn
  • 135
You need to install two software packages to make the internet connectivity work consistently without breaking. They are wvdial and gnome-ppp (The front-end tool to configure wvdial).
1) Install wvdial package
Open terminal,(alt+ctrl+t) and type the following command
sudo apt-get install wvdial
2) Install gnome-ppp
sudo apt-get install gnome-ppp
3) Open gnome-ppp from the terminal.
sudo gnome-ppp
4)You have to enter your BSNL 10-digit mobile number in the Username & your password. Type *99# in the number row. Then press the Setup button below.
5) In the Setup window below, click the “Detect” button to identify the device ID of the USB port in which you have inserted your USB modem. The tool would automatically detect the Device, Type and Speed of your USB modem. Once it has deteced, please the “Close” button below.
Once this is done click on Connect!!!
You could also configure it through the terminal. This link should help you to configure it via terminal.
You could also try installing ixconn.you can get it here
Mukund
  • 2,122
Did you enable Mobile Broadband in the network menu? Once you enable it, a wizard will pop up to add your dongle. Choose India and then BSNL and choose your appropriate plan. I followed the same procedure for my Reliance 3G dongle. No need for the terminal at least in my case. Ubuntu installed all the relevant packages automatically.
pratnala
  • 749
