My problem is the following, since an upgrade to Kernel 3.7, my cdrom/DVD drive has dissapeared. There is no trace of /dev/sr0 /dev/cdrom0 and others. The drive does not show up in dmesg.
I see many errors like prereset failed erro = -19 and AE0x300B.
I tried several things, like adding modprobe.blacklist=pata_acpi to grub : GRUB_CMDLINE_LINUX="modprobe.blacklist=pata_acpi" I also tried upgrading to (I believe not supported) 3.7.1-030701-generic and a downgrade to 3.5.4 (here my dvd shows up, but the network is not working). As everything was working in 3.5, I would like to install 3.5.0.21-generic, but I can not find instructions / location how to do this.
Any suggestions ? (both are appreciated : going forward to solve my dvd drive problem or downgrade the kernel).
Did you uninstall the 3.5.0.21 kernel? If you did not, uninstall the 3.7 and 3.5.4 kernels and you're done. To be sure you do have a working kernel in a terminal type dpkg --list | grep linux-image.
If you did uninstall the 3.5 kernel, you can:
  1. Disable the ppa which installed the 3.7 kernel by opening Software Sources. This has the consequence that the Nvidia packages won't get updated from the PPA.
  2. In a terminal type: sudo apt-get update followed by sudo apt-get install linux-image. Kernel 3.5 should be installed.
  3. Reboot with the newly installed kernel.
  4. Uninstall the 3.7 and 3.5.4 kernels and reboot.
To Do
  • 15,833
