After installing 12.04 Ubuntu I tried to install Kile but when I was trying to install Kile , it showed that "failed to download package file . Check your internet connections" . But my INTERNET is working properly even I can download updates available . How can I solve this problem ?
Still trying to install it but it says " Failed to download package files .Check your Internet connection. , Failed to fetch http://bd.archive.ubuntu.com/ubuntu/pool/main/v/virtuoso-opensource/virtuoso-opensource-6.1-bin_6.1.4+dfsg1-0ubuntu1_i386.deb Size mismatch "
There is no problem in INTERNET browsing so where is the problem ??
dobey
  • 41,650
I ran into this same problem while trying to get a system image ready for next semester.
I got the same errors when I tried to use the Ubuntu software center.
So I opened a terminal and ran sudo apt-get install kile. This also had errors, so I ran this command, sudo apt-get update, in the terminal.
After the updates I was able to run the first command but modified it to this, sudo apt-get install kile --fix-missing.
At this time, it is still running as latex takes a while to install, but it seems to be working.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
scminty
