Valve's steam client is now Open to all said a link and so I decided to install Steam Client on my Ubuntu 12.04 machine to try it out.
I downloaded the deb file from this page.
Once after the download is completed and I double-clicked to install it and as expected Ubuntu software Centre is launched but with error as stated below:
Internal Error "The file /home/pras/Downloads/steam_latest.deb can't be opened".
Even I tried to install it via
sudo dpkg -i steam_latest.deb
which also throws errors
pras@Tuxbox:~/Downloads$ sudo dpkg -i steam_latest.deb
[sudo] password for pras:
(Reading database ... 408406 files and directories currently installed.)
Unpacking steam (from steam_latest.deb) ...
dpkg-deb (subprocess): short read on buffer copy for failed to write to pipe in copy
dpkg-deb: error: subprocess paste returned error exit status 2
dpkg: error processing steam_latest.deb (--install):
 short read on buffer copy for backend dpkg-deb during `./usr/lib/steam/bootstraplinux_ubuntu12_32.tar.xz'
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf.index...
Processing triggers for desktop-file-utils ...
Processing triggers for gnome-menus ...
Processing triggers for hicolor-icon-theme ...
Processing triggers for man-db ...
 steam_latest.deb
So how should I install it?
Eric Carvalho
  • 55,453
Prashere
  • 317
I had this same problem.
To get around it I used 'wget' in a terminal to download the file.
When the interruption happened 'wget' just reconnected and continued to download the file.
I used the following command
wget http://repo.steampowered.com/steam/archive/precise/steam_latest.deb
