I have recently moved from Windows to Ubuntu 12.10. I have an AOC portable laptop monitor (Model number e1649Fwu), which works solely through USB.
It works fine on Windows, but I cannot work out how to find/install drivers for Ubuntu. I found this forum thread.
Any help would be greatly appreciated.
Update: It now displays the purple Ubuntu start-up screen, but an error is displayed on the second monitor when login is complete. I get Ubuntu as expected on my primary screen, and on the second screen it gives a general protection fault.
I followed the steps on this Ask Ubuntu question about installing a USB-link monitor, but the displaylink.c file throws C errors when I run:
./configure && make && make install
I tried to fix these by modifying the C code, but no luck. I also tried using the xorg.conf file used in this tutorial, but this also doesn't work.
Am I right in thinking that it is just a matter of getting the xorg.conf file correct now?
This is a picture of the error shown on the second screen:
error on second screen
Since it's a DisplayLink device, try to use one of the how-to's for DisplayLink & Ubuntu, e.g. How do I use a DisplayLink monitor?
falstaff
  • 965
Much later but on Ubuntu 20.04, the AOCI1659FWUX model portable monitor works straight out of the box (almost) if you download the driver from here: https://www.displaylink.com/downloads/ubuntu Unzip and install it as instructed here: https://engineerworkshop.com/blog/adding-a-portable-usb-monitor-to-ubuntu-how-to-set-up-a-displaylink-driver/
But make sure your laptop has two USB 3.0 ports. Mine has 2 next gen 3.2 which are backwards compatible so no squiggly lines, just works and I am able to use portrait orientation and landscape.
how do to install the display drivers for a displaylink usb monitor on 13.04?
Some peple are saying it worked on earlier versions of ubuntu with a manual kernal upgrade. Someone else said Fedora 18 supports it out of the box...
Also, here is support for a raspberry pi!!! http://imkiyoung.wordpress.com/2012/09/18/raspberry-pi-and-aoc-e1649fwu-usb-powered-led-monitor/
jacobfogg
  • 263
