I own a HP probook 4530s.
I installed ubuntu 12.04 along side my windows 7 professional OS. While in window 7 everything works properly in terms of wire and wireless connection.
On Ubuntu 12.04 my wired connection doesn't work at all and wireless connection works only when I check off enable wireless then recheck enable wireless.
When I recheck enable wireless, the wireless connection only works for about 30 seconds then it goes offline again.
Jorge Castro
  • 73,717
Ubuntu usually allows you to easily connect to a wireless network by just clicking the name of the network you'd like to use, but most wifi cards need a proprietary driver to work. So go to the "System Settings" > "Additional Drivers" to see if you need to install a proprietary driver for your wifi card.
So if new drivers need to be installed do so by using a wired connection or a mobile broadband.
Can you give the output when you run ifconfig and sudo lshw -C network on your terminal
and as far as wired connection is concerned
Login as root
type : gedit /etc/network/interfaces in the terminal window.
add the following lines to the end of the file auto eth0
`iface eth0 inet dhcp`
save and quit.
now restart the network. - How to restart the networking service?
Mukund
  • 2,122
