55
aks@aks-K55VD:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 12.04.1 LTS
Release:    12.04
Codename:   precise
used the command lsb_release -a and found 'No LSB modules are available'
LSB->http://en.wikipedia.org/wiki/Linux_Standard_Base
what does that mean by the unavailability of this module and how can they be made available to my system?
devav2
  • 37,290
Aks
  • 781
Since there are no lsb modules installed in your machine, you get that message.
You can install the lsb modules using the command
sudo apt-get install lsb-core
After installation, when you run the same command you wont see the message saying 'No LSB modules are available'
lsb_release -a will display some basic info about to which LSB specifications your system/OS complies with.
Hope this helps.
devav2
  • 37,290
