10
OS: Ubuntu 12.04 LTS
$sudo apt-get install libsqlite3-dev
The following packages have unmet dependencies: libsqlite3-dev : Depends: libsqlite3-0 (=3.7.9-2ubuntu1) but 3.7.9-2ubuntu1.1 is to be installed
$sudo apt-get install libsqlite3-0
Building dependency tree
Reading state information...
Done libsqlite3-0 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 103 not upgraded.
I have also try to download the newest package on https://launchpad.net/ubuntu/raring/i386/libsqlite3-dev/3.7.15-1
and have read this: https://getsatisfaction.com/jolicloud/topics/installing_libsqlite3_dev_doesnt_work
Ubuntu responsed: "cannot install libc6:i386" or "is not statisfiable..."
devav2
  • 37,290
This appears to be a problem with some of the 64-bit packages being out of sync with the 32-bit packages (3.7.9-2ubuntu1 vs. 3.7.9-2ubuntu1.1).
The following answer is shamelessly cut'n'pasted from the thread at http://www.kubuntuforums.net/showthread.php?60125-Can-t-install-anything-bad-libsqlite3-0-amd64 which I recommend for a more thorough description (as well as steps to verify that this is indeed your problem.)
  1. Download the 64-bit version:
    apt-get download libsqlite3-0:amd64
  2. Download the 32-bit version:
    apt-get download libsqlite3-0:i386
  3. Forcibly remove the existing 64-bit version:
    sudo dpkg --force-depends --purge libsqlite3-0:amd64
  4. Forcibly remove the existing 32-bit version:
    sudo dpkg --force-depends --purge libsqlite3-0:i386
  5. Manually install the 64-bit version:
    sudo dpkg --install libsqlite3-0*amd64.deb
  6. Manually install the 32-bit version:
    sudo dpkg --install libsqlite3-0*i386.deb
Then see if your install of the -dev works, since one of those should match what it's looking for.
Jorge Castro
  • 73,717
