Previously, I need to clear documents history, so I Googled and found this:
http://www.watchingthenet.com/ubuntu-tip-clear-disable-recent-documents.html
I did the step, and then when I opened gedit in root terminal, I've got this:
root@dellph1-desktop:/# gedit
(gedit:8224): GLib-CRITICAL **: g_bookmark_file_load_from_data: assertion `length != 0' failed
(gedit:8224): Gtk-WARNING **: Attempting to store changes into `/root/.recently-used.xbel', but failed: Failed to rename file '/root/.recently-used.xbel.FP7PPV' to '/root/.recently-used.xbel': g_rename() failed: Operation not permitted
(gedit:8224): Gtk-WARNING **: Attempting to set the permissions of `/root/.recently-used.xbel', but failed: Operation not permitted
And it's happpened in user terminal:
dellph1@dellph1-desktop:~$ gedit
(gedit:9408): Gtk-CRITICAL **: gtk_accel_label_set_accel_closure: assertion `gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
I really hope someone helps in this case, thank you.
dellphi
  • 455
Use this
(nohup gedit 2>/dev/null &)
This runs gedit in the background in a sub-shell, with nohup. Hence, the error messages are handled by nohup, and closing the terminal wouldn't affect gedit. A simpler way would be:
gedit &> /dev/null
This just discards any error messages from gedit.
muru
  • 207,228
I'm recommending that you not use gedit via the root user. Try and use gedit through sudo instead.
Reinstalling gedit won't help, I believe you need to undo the damage done by following the guide.
