-1
I had installed ubuntu 12.04 in my Dell Vostro 3460. Initially wired as well wireless both are not working.
After installing compat-wireless-2012-07-03-pc.tar.bz2 wired network fine but wireless is not working. Previously both were working fine with ubuntu 11.10. Also presently both network are working fine in Win7.
lspci:
00:00.0 Host bridge: Intel Corporation Ivy Bridge DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Ivy Bridge PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Ivy Bridge Graphics Controller (rev 09)
00:14.0 USB controller: Intel Corporation Panther Point USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation Panther Point MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation Panther Point USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation Panther Point High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 1 (rev c4)
00:1c.4 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 5 (rev c4)
00:1d.0 USB controller: Intel Corporation Panther Point USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation Panther Point LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation Panther Point 6 port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation Panther Point SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 0de9 (rev a1)
02:00.0 Network controller: Broadcom Corporation Device 4365 (rev 01)
03:00.0 Ethernet controller: Atheros Communications Inc. AR8161 Gigabit Ethernet (rev 10)
iwconfig:
lo        no wireless extensions.
eth0      no wireless extensions.
ifconfig:
eth0      Link encap:Ethernet  HWaddr 84:8f:69:d4:35:9b
          inet addr:10.24.22.72  Bcast:10.24.31.255  Mask:255.255.224.0
          inet6 addr: fe80::868f:69ff:fed4:359b/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:15332 errors:0 dropped:0 overruns:0 frame:0
          TX packets:10425 errors:0 dropped:0 overruns:0 carrier:1
          collisions:0 txqueuelen:1000
          RX bytes:9262594 (9.2 MB)  TX bytes:1572030 (1.5 MB)
          Interrupt:16
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:1432 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1432 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:145656 (145.6 KB)  TX bytes:145656 (145.6 KB)
Eric Carvalho
  • 55,453
Nilesh
I have a Vostro 1500 that I just set up recently and I had to do a bios update in order to get my wireless to work.
zkent
  • 191
Maybe wifi driver problem.
Try like this
First we have to remove the bcmwl kernel source: sudo apt-get remove bcmwl-kernel-source
Then again install : sudo apt-get install bcmwl-kernel-source
Beginner
  • 491
Another reason for not detecting Wifi after new installations or such issues might be a problem with Wireless Network Adapter Drivers.
You can first check which Wifi Network Adapter is there in your PC.
lshw -C network
Mine Wireless N/W adapter was Realtek rtl8723be. So I installed the drivers from :
https://github.com/lwfinger/rtlwifi_new
Thanks.
